gmhyman's avatar
gmhyman
Guide
Jan 05, 2016
A6210 doesn't automatically reconnect after reboot
I have a brand new A6210 running on a windows 10 deskside machine.  In general, it works fine, connects to my R7000 router at 5G speeds, etc.
One problem - after each reboot, I have to manually reconnect, either with A6210 Genie, NetGear Genie or Windows wifi settings.  All 3 work equally well.  Is there any way to really tell this device to reconnect automatically.
Note that my prior wifi adaptor (ASUS usb-AC56) had the same problem, as well as causing others, which is why I replaced it.
Any suggestions most welcome.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi gmhyman,
    Try to connect to the network using the windows utility(the icon on the system tray). Make sure that "Connect automatically" is checked before clicking connect.
    • gmhyman's avatar
      gmhyman
      Guide
      Unfortunately I did that (i.e. made sure the "connect automatically" box was checked) long ago.  Any other ideas?  I suspect some very subtle registry weirdness, but I'm not enough of a registry person to determine if that's true.
      • JamesGL's avatar
        JamesGL
        Hi gmhyman,
        You've mentioned that it also happens on your previous adapter which is a different brand. There might be a setting on the Windows 10 that needs to be configured. Have you tried checking on microsoft team?
  • I have the same problem, although it is an A6200 adaptor connecting to an R6300V2.   I had been getting download speeds up to 45Mbps. My ISP after 3 service calls, said I needed a range extender. They installed an R6300EX, still getting 45Mbps.  The 4th service call they finally sent a tech that knew what he was doing. He tossed the extender(called “Default-5g_ext”) and instead of the mode being connected to 2.5Ghz, he changed the router to 5Ghz and we were getting up to 240+Mbps.
      When he left  My default router setting was pointing to the name “default-5G’  and he explained that there was another setting (“default-5g_5ext”) pointing to the range extender R6300V2.  On Win 10,  I did not previously have the problem with my D-link router.  I show 2 modes that my ISP configured. Originally because I was only getting download speed upto 45Mbps, they said I needed a range extender. So, I had them install a 6300EX, but still getting 45Mbps.  Finally, a tech came out that knew what he was doing and tossed the extender, reconfigured the mode from 2.4 Ghz to 5 Ghz, I was then upto 240Mbps.  Now this referenced problem. He left me with 2 modes called "Default-5g"-(connects at 240+Mbps)  and Default-5G_ext"-(connects at 45 Mbps).  When I reboot(or sometimes over night with no intervention) it switches back to "Default-5G_ext) at 45. I cannot find the "Default-5g" to even reconnect.  How (or can I) get rid of the 5G_ext?
    • JamesGL's avatar
      JamesGL
      Hi Smintz,
      How many wireless networks do you have?
      Can you provide the setup of your network?
      Did you set the R6300v2 as the router or an AP?
