Pantheren27
Dec 15, 2020Follower
A6210 Keeps disconnecting, Now wont even connect to 2.4 ghz wifi
Im sorry to be a bother during these horrible times but I can't seem to get this thing to work anymore with my 2.4 ghz wifi and even when it did work it constantly disconnected and cause me problems ...
michaelkenward
Dec 19, 2020Guru - Experienced User
This conversation covers some of the issue that to you might like to investigate:
A6150, AC1200 getting high ping during games - NETGEAR Communities
Same hardware. Same challenge.
pkdddog
Dec 28, 2020Aspirant
I am using the same model of adaptor, since I have updated my Window 10, which I havent done for a long while, my adaptor started to disconnect constantly. When it happend, I just have to search wifi and connect manually after connection lost (maybe 2-3 times a day). Just wondering is it a known issue?
