Bricemb96
Dec 13, 2022Tutor
A6210 NEEDS UPDATE! PLEASE STOP IGNORING THIS NETGEAR!
 Regarding A6210 - AC1200 High Gain WiFi USB Adapter — 802.11ac Dual Band USB 3.0  Windows 11.  A6210 Software Version 1.0.0.39     I have been sent here by support to post this because they refuse to...
- Dec 13, 2022
Bricemb96 wrote:
Yeah the representative was rude the entire time, and clearly lied just being lazy and careless.
All this together changes the way i see Netgear completely.----Not sure if you talked to netgear as their support is only free for the first 90 days. After that, its paid support. Most of the consumer networking gear uses this model as its expensive to run support and most people try to use it as their own IT department (not saying you were. Just explaining why they've switched to this model)
So there is no manager that actively reads these as thought, and mods are rare that have no ability to escalate the issue either.----There's mods on here but they tend to be more active on the more expensive devices (like orbi or readynas forums)
What did you mean by highlighting the issue you just meen posting it here right?---It does help to have on here because the more posts they see about the same issue, the more likely they are to consider it a systemic issue and looks for updates versus thinking its just a single persons issue.
netgear is crap. Got it.----Didn't say that. Just explaining the current consumer gear issues you'll find for most companies.
Thanks for the reply though i do appreciate it! plemans
There's a few posts on the forum that might help that have had similar issues.
https://kb.netgear.com/23352/A6200-A6210-WNDA3100v2-wireless-adapter-intermittently-disconnects
Re: A6210 keeps disconnecting - NETGEAR Communities
SOLVED: Constant Disconnection of Netgear A6210 Ad... - NETGEAR Communities
michaelkenward
Apr 27, 2024Guru - Experienced User
Hugzy wrote:
Why is the Netgear A6210 wireless adapter still being sold in stores if it has NO Windows 11 support?
Does it claim to support Windows 11?
Have you installed the Windows 10 drivers?
A6210 Software Version 1.0.0.39 - NETGEAR Support
I have yet to come across a device that works in Windows 10 but not Windows 11.
Did you try this?
Hugzy
Apr 27, 2024Tutor
As Windows 11 is the ONLY windows that is NOT end of life, there should be ONLY Windows 11 devices for sale at major retailers such as Best Buy unless CLEARLY marked that they are for Windows no longer supported.
Your assholish comment is why my companies will no longer purchase Netgear products. We will also strongly recommend to our clients & customers to avoid these products.
