mrsqueezy
Apr 16, 2017Aspirant
A6210 Software Version 1.0.0.36 Disconnections
Hi Again
So I've updated Windows and decided to try .36 after the disaster that was .35
Good news the driver solved all the issues that I had with .35
Bad news is that I keep having issues with limited connectivity/ disconnections to the internet.
- Its not linked to heavy downloads even everday browsing has caused me issues
- I updated all my drivers etc and checked again with slimdriver that a member recommended
- Still having issues with the connection
So I have uninstalled Genie again along with the .36 driver and am using the driver that comes with Win 10.
The driver that comes with Windows is not perfect (It struggles to connect on start up) however the connection appears more robust than that of the netgear one.
mrsqueezy
- updatedriversAspirant
Having the same issue with the new driver update (1.0.0.36). Keep getting disconnected every few minutes.
- VE6CGXMaster
Sure bet of updating to new driver is after all traces of older driver is removed(deleted) using control panel 'programs & features'
- mrsqueezyAspirant
Hi,
I'm not 100% on your statement.
"Sure bet of updating to new driver is after all traces of older driver is removed(deleted) using control panel 'programs & features'"
I fully removed all traces of .35 shortly after they released it (via control panel I believe but it was a long time ago).
I have been using Windows own driver up until I installed creators update where I tried v.36
- I am now accessing the internet using Windows 10 built in driver
- JamesGLNETGEAR Employee Retired
Hi All,
Try installing the standalone driver for A6210.
- mackel95Initiate
Hi,
Not sure if I have the same problem as you but I get disconnected about 30min-1 hours after I've turned my computer on. The A6210 goes into some "installing"-mode and I lose internet during this period. Do you have the same?
- mrsqueezyAspirant
Hi,
The dropouts appeared to be random
I could have long sessions connected then sudden disconnects
I've also had issues where I've just turned on the PC
