Mmbooger
Jun 20, 2026Aspirant
A7000 stops working with SVM mode
I'm on Windows 11 pro.
I'm trying to enable SVM mode on my BIOS so I can run docker, but when I reboot after enabling it, the wifi no longer works. Even in windows' settings, when I click 'network and internet' the settings window turns red and crashes
When I disabled SVM mode, wifi and the settings network page works.
Any idea what's going on?
Hmmm. Internet search for running Docker on Windows 11 does not mention BIOS:
It's an AMD setting ("secure virtual machine"). It's not needed for Docker, but I believe it is needed for WSL2.
Is this happening when the A7000 is removed from the PC?
- MmboogerAspirant
When I remove the A7000, it still continues to have the network and internet setting page turns red and crashes.
It might be worth considering getting a WiFi adapter that is certified to be compatible with Windows 11 Pro. The A7000 firmware was last updated in 2018 and shows compatibility with Windows 7/8/10.
Since the A7000 appears to function correctly until SVM mode is enabled in the BIOS, my thought was there might be something in the A7000 firmware that cannot handle SVM mode on Windows 11.
Could be. Hopefully not, since the product is EoL, so Netgear won't update anything. But also could be an outdated BiOS or chipset drivers on the PC.
Gemini is saying that some users have found that disabling "Fast Boot" in the BiOS or "Fast Startup" in the Windows power settings resolves the problem. Could be true, since the AI large language models are often trained on reddit...
Its not that easy to find the "Fast Startup" option, it's in control panel -> power options -> change what the power button does. Note you need to open the control panel with elevated privileges to change the setting.
But getting a new wifi adapter is of course a reasonable alternative, especially if you have a wifi 6 or wifi 7 router.
- MmboogerAspirant
For the sake of visibility, my router is Nighthawk CAX80, Firmware Version V5.1.1.8
I recently ran all the update files from ASUS for my motherboard and whatnot.
Do you see the crash if you boot up in safe mode with networking? (Wifi might not actually work - not sure if wifi is disabled in that mode).
- MmboogerAspirant
Quick Update:
I bought a MSI usb network adapter WiFi 7 from MicroCenter last night.
I got it working with SVM mode disabled.
I noticed that the wifi wouldn't work for a little bit after it boot up, and then after 10 mins, the docker virtualization not enabled error pops up and the rest of the start up programs start to run.
I uninstalled Docker, but I haven't reboot yet to see if that removes the 10 min loading.
- MmboogerAspirant
I tried safe mode and I think the networking and internet settings page worked.
I bought a MSI usb network adapter WiFi 7 from MicroCenter last night.I got it working with SVM mode disabled.
- MmboogerAspirant
Another update, I enabled SVM mode and booted and left for a little bit, then came back and the wifi was now working.
I'm going to try to install Docker again in a little bit and see if that breaks again.
thanks for your help everyone even though the issue doesn't seem to be due to the netgear item
great news! thx for following up.
