mondenath
Jun 17, 2016Prodigy
AC6200 USB 2.0 VS USB 3.0 MODE
Hi Team, I was wondering which is stable and provide max throughput. So far wireless adapters never reached the max theoritical or practical throughput of USB 2.0 ie 40+ MBps. Hardly 20 Mb...
mondenath
Jun 21, 2016Prodigy
I got my adaptor today and it say in other region africa. Is that locked to that region for some reason.
- mondenathJun 22, 2016Prodigy
Is it true the r7000 being wave 1 cant tgo 160mhz only 80mhz.
- aalexandrebetaJul 23, 2016Master
for me it's the same no changes!
- mondenathJul 23, 2016Prodigy
what no change. Can you elaborate.
The speed on 2.0 vs 3.0 change is visible if you use the right medium/
It can go upto 40MB/s on usb 3.0 but only 33MB/s on 2.0 max speed.
As port limitation is the cause not the wifi bandwidth limitation.
