mondenath
Jun 17, 2016Prodigy
AC6200 USB 2.0 VS USB 3.0 MODE
Hi Team, I was wondering which is stable and provide max throughput. So far wireless adapters never reached the max theoritical or practical throughput of USB 2.0 ie 40+ MBps. Hardly 20 Mb...
mondenath
Jun 21, 2016Prodigy
I got my adaptor today and it say in other region africa. Is that locked to that region for some reason.
mondenath
Jun 22, 2016Prodigy
Is it true the r7000 being wave 1 cant tgo 160mhz only 80mhz.
- aalexandrebetaJul 23, 2016Master
for me it's the same no changes!
- mondenathJul 23, 2016Prodigy
what no change. Can you elaborate.
The speed on 2.0 vs 3.0 change is visible if you use the right medium/
It can go upto 40MB/s on usb 3.0 but only 33MB/s on 2.0 max speed.
As port limitation is the cause not the wifi bandwidth limitation.
Same dongle 2 laptops one with USB2 the other USB3 38Mb/s!!
