mondenath
Jun 17, 2016Prodigy
AC6200 USB 2.0 VS USB 3.0 MODE
Hi Team, I was wondering which is stable and provide max throughput. So far wireless adapters never reached the max theoritical or practical throughput of USB 2.0 ie 40+ MBps. Hardly 20 Mb...
aalexandrebeta
Jul 23, 2016Master
for me it's the same no changes!
mondenath
Jul 23, 2016Prodigy
what no change. Can you elaborate.
The speed on 2.0 vs 3.0 change is visible if you use the right medium/
It can go upto 40MB/s on usb 3.0 but only 33MB/s on 2.0 max speed.
As port limitation is the cause not the wifi bandwidth limitation.
- aalexandrebetaJul 23, 2016Master
Same dongle 2 laptops one with USB2 the other USB3 38Mb/s!!
- TheEtherJul 23, 2016Guru
mondenath wrote:what no change. Can you elaborate.
Just to be clear, the A6200 is a USB 2.0 Wi-Fi adapter. It doesn't support USB 3.0. It can be plugged into a USB 3.0 port, but that port will run in USB 2.0 mode. Any speed differences are you seeing must be due to differences between the computer's handling of the USB 3.0 vs 2.0 port.
