mondenath
Jun 17, 2016Prodigy
AC6200 USB 2.0 VS USB 3.0 MODE
Hi Team, I was wondering which is stable and provide max throughput. So far wireless adapters never reached the max theoritical or practical throughput of USB 2.0 ie 40+ MBps. Hardly 20 Mb...
mondenath
Jul 23, 2016Prodigy
what no change. Can you elaborate.
The speed on 2.0 vs 3.0 change is visible if you use the right medium/
It can go upto 40MB/s on usb 3.0 but only 33MB/s on 2.0 max speed.
As port limitation is the cause not the wifi bandwidth limitation.
aalexandrebeta
Jul 23, 2016Master
Same dongle 2 laptops one with USB2 the other USB3 38Mb/s!!
