mondenath
Jun 17, 2016Prodigy
AC6200 USB 2.0 VS USB 3.0 MODE
Hi Team, I was wondering which is stable and provide max throughput. So far wireless adapters never reached the max theoritical or practical throughput of USB 2.0 ie 40+ MBps. Hardly 20 Mb...
mondenath
Jul 23, 2016Prodigy
I agree but you pointed no difference. Yes there is difference as it matters how you transfer files. Say pc-pc USB 2.0 to pc or USB 3.0 to pc.
As reading from attached USB 2 gets you 18MBps but same if you read from USB 3.0 can reach 33MBps
It matters which band you are connected and connection rate as well
TheEther
Jul 23, 2016Guru
Are you talking about a direct USB cable connection between 2 PCs? How is that relevant to this discussion?
My point is that a USB 3.0 port with an A6200 plugged into it is going to run in USB 2.0 mode.
Is this with your A6200?
Correct.
