ecamargo
Feb 08, 2017Follower
Best Wifi desktop usb to use with new Orbi
I'm in a room next to garage that has firewall (actual wall, not network), what's the best recommended way, besides running a cable to master bedroom where the IDF is, but the wife won't allow a cable going up and down the wall, anyway, do you recommend USB wifi on the PC or should I get a Powerline, if so, which one? I have used the power ethernet before, and had lots of problems with drop offs, no connectivity, etc. I just purchase an Orbi because I heard it could cover 3000 sq house. Current speed is 43.55mbps down and 9.51 upload. I was told that the linksys can do over 300 mbps with this model. haven't seen that yet.
Please advise
Thank you
EThan
Hi ecamargo,
You can check the A6210 AC wireless adapter for your desktop.
