Dustrega
Aug 09, 2015Star
Event 10400: A6200
Hello all,
I have trawled Google, tried alternate drivers ranging from signed Netgear Beta drivers to BSOD-causing chipset manufacturer drivers. After hunting down several errors in my event log, one still persists among all else.
Event 10400, NDIS
The network interface "NETGEAR A6200 WiFi Adapter" has begun resetting. There will be a momentary disruption in network connectivity while the hardware resets.
Reason: The network driver requested that it be reset.
This network interface has reset 4909 time(s) since it was last initialized.
This was merely leaving the wireless adapter attached to my computer overnight. The only way that I can fix the problem of intermittent connection issues is by unplugging the adapter and plugging the adapter back in, because it's a crapshoot whether the driver will restart on its own and regain connectivity.
It's baffling that the device worked with Windows 7, then I update to Windows 10 and suddenly with a new driver it goes straight down the drain in terms of performance:
- Disconnects at random
- No networks shown
- Can only remedy quickly by unplugging and reconnecting the device
Any thoughts?
Oh, you can get my DxDiag information here:
https://www.dropbox.com/s/vbq5wdg48h1thqi/DxDiag.txt?dl=0
A copy of the event is here (device reset counter still rising):
https://www.dropbox.com/s/qnk3xo4ni9zfq4f/Event%2010400.txt?dl=0
Months. Take that word in. It has been MONTHS, since Netgear has had any tangible information or updates for this particular problem. It has been MONTHS, since I have seen any viable solution or suggestion to fix this problem. In case you don't know what I'm talking about, I would suggest looking here and here. You have taken my information, Netgear, and done what with it? Nothing, absolutely nothing. No word, no PMs, no credibility. I'll grant the guise of effort, but that is about all I will grant. I have been compliant with all requests for information and patience. I have been completely understanding that things like this take time, but MONTHS? There are issues with your hardware that have been around since Windows 8, and now with the release of Windows 10 the problem has resurfaced. Living proof that the problems you DON'T SOLVE will come around to bite you. Are you going to learn this time? Probably not, but as long as you got my money, and that of others, at one point or another you probably couldn't care less.
Surprise surprise, 3 months later and still nothing. Pretty rediculous.
- ArothAspirant
Same problem here with a WNA3100 and Windows 10. According to a Google search, this is not limited to Netgear devices though. I've seen posts about Intel adaptors and dell ones as well. It MIGHT be a broadcom issue (since i would venter they all use broadcom radios) but my money is on something **bleep**y Windows 10.
- DarrenMSr. NETGEAR Moderator
Hello Dustrega
We are currently working on the issues with the windows 10 drivers we have a thread with some ways to get them working properly and also we are collecting information from the community about the issues they are having so we can fix the issues. Please take a look at this thread.
DarrenM
Hi there, has there been any solution found to this problem yet? I have the same issue with my a6200 randomly droping connection. Shows up the same in event viewer as well. Super frustrating, and phone support can't help due to the randomness of this problem. Any advice would be welcome.
- JamesGLNETGEAR Employee Retired
Hi Plattfish,
Welcome to Community!
Please follow the steps below and provide feedback if it resolves.
- With the A6200 plugged in, uninstall the old NETGEAR software and drivers. To do this, open Control Panel.
- Click on “Uninstall a program”.
- Click on “NETGEAR A6200 Genie” and click Uninstall
- Once uninstall has completed, unplug your A6200 adapter and restart your PC.
- If you are using USB 3.0, you will need to upgrade the USB host controller.
- To determine if you are using USB 3.0, see Microsoft’s support article USB 3.0 Devices.
- For information on how to update the USB host controller driver, visit your motherboard manufacturer’s website.
For more information on updating drivers in Windows 10, see Microsoft’s support article: How to Install and Update drivers in Windows 10.
- Ensure that you have installed all of the necessary updates for Windows 10 before proceeding. For more information on installing Windows updates, see Microsoft’s support article Service Pack and Update Center.
- Download and extract the A6200 softwareto a convenient place such as your desktop.
- Choice one of listed execution file and run.
- standalone-V1.0.011-win8.1_win10_signed.exe (with NETGEAR Genie )
- setup-V1.0.0.26-win8.1_win10_signed.exe (Driver Only)
- Follow the on-screen installation instructions (insert the adapter when prompted)
- When the installation has completed, restart your PC.
JamesGL
Community Team
Hello Darren,
Thank you for responding. My ire has subsided a little bit thanks to you. Per your request, I have replied to the thred you specified here. You may close this thread, if you wish.
Best regards,
Dustrega
More information:
This event occurs every 30 seconds btw. Fun times.
Also, is it really necessary to run the NetGroup Packet Filter when your router isn't even in play, Netgear?
I have tried the steps here:
http://kb.netgear.com/app/answers/detail/a_id/23352
Unfortunately, no luck whatsoever. I would've thought that the community would be all over this. Did I miss something in your extensive forums or KB, Netgear?
