lukedukeb's avatar
lukedukeb
NETGEAR A6210 is not found?
I am currently using a windows 10 pc and just this bought this adapter 3 days ago and arrived yesterday. i was setting it up today, so i go ahead and put in the cd and then click setup and it begins the process, untill it says insert your adapter into a usb port. So i go ahead and do that but it keeps saying it cant be found? I am so far very upset with this adapter and would not recommendit.
  • I have a Tivo Roamio connected to an HD antenna in my home office (not connected to cable in the rest of the house).  I've purchased a Netgear A6210 recommended by Best Buy to connect Tivo to my wifi router.  I've run the installation CD, also installed latest drivers from Netgear downloads.  No light on adapter and I keep seeing "Netgear adapter not found."
    I next plugged the new adapter into usb on my computer.  Same result.  I have a different Netgear adapter on that same PC (router is 70' away) and my wifi connection is fine for my PC.  But no joy with the Tivo.  Any suggestions?  Did I get the wrong type of adapter?
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi drjack,
      The adapter only works with Windows based OS computer. It may not be compatible with your TiVo.
      • JamesGL's avatar
        JamesGL
        Hi drjack,
        If the TiVo has ethernet port, you may try checking WNCE3001 or WNCE4004.
  • Is the USB port known good one? Can you try on another port?
    Any light on the dapter when plug it in?
