roiei's avatar
roiei
Netgear A6210 not showing 5ghz band
Hello,
I've purchased this A6210 dongle around 3 months ago, the 5GHz was working fine around 2 month and just one day stopped working.
I didn't have the time to try and solve it, so I've just used the 2.4GHz, now I'm trying to solve it and nothing is working.
I tried to:
1. Uninstall-install (driver alone, and software and driver - version 1.0.0.34)
2. Change USB connector position
3. Configure "Only 5GHz" - not showing my network
etc.
This is really annoying that I can't use the 5GHz - do you have any suggestions?
  • Please close this topic, I found the solution (changing the name of SSID aand PASS)
    • noeltom's avatar
      noeltom
      Tutor
      I have the same problem. Can you please explain your solution in more detail?
      • michaelkenward's avatar
        michaelkenward
        My guess is that they changed the wifi SSID and password on the router.
        Without more details of what you mean by "the same problem" there is no way of knowing of this applies to you.
