ToothGrinder
Feb 17, 2019Aspirant
Random Disconnects and internet loss
I have been having issues with my A6210 USB adapter. When I start the computer it will connect and disconnect about 2-4 times before the connection is stable. After that, if I am playing an online ga...
Blanca_O
Feb 18, 2019NETGEAR Employee Retired
Hi ToothGrinder
Welcome to NETGEAR Community!
Try performing the troubleshooting steps here: https://kb.netgear.com/23352/
Blanca
Community Team
- ToothGrinderFeb 18, 2019AspirantUnfortunately when I look into those settings "minimum power consumption" it's not there. Does it possibly have a different name?
These are the options available to me using my A6210 Wifi adapter.
Are any of these settings related to my issue? If so, which should I try to change?
- Blanca_OFeb 18, 2019NETGEAR Employee Retired
- ToothGrinderFeb 18, 2019AspirantWindows 10
- Blanca_OFeb 26, 2019NETGEAR Employee Retired
Hi ToothGrinder
Please go back to Device Manager > right-click NETGEAR A6210 > select Properties > go to Power Management tab > uncheck the option that says “Allow the computer to turn off this device to save power” > Click on OK and then restart your computer.
Blanca
Community Team
