MrMurica11
Mar 21, 2022Aspirant
USB Wifi Adaptor A6210 connection issues
I purchased this adaptor on Oct. 2, 2021 and didn't really have any issues with it. After a little while I noticed whenever I booted my pc, it would keep connecting and disconnecting from my school's...
michaelkenward
Mar 22, 2022Guru - Experienced User
MrMurica11 wrote:
Motherboard: ASUS STRIX B350-F GAMING
(motherboard doesn't have most recent bios update)
The BIOS is much less important than the chipset drivers.
Things like USB rely on third party drivers, The support pages for your motherboard usually have a bunch of updates on the originals.
The symptoms you describe certainly sound like something at that level.
MrMurica11
Mar 22, 2022Aspirant
Ah, makes sense. I found the most recent chipset driver on the page for my mobo. I'll update it and see what happens
