sktn77a
Mar 01, 2017Virtuoso
WNCE2001 pass through IP address
I'm using a Netgear WNCE2001 to connect a NAS drive to my wireless network (Netgear R7000). Everything appeared to be working fine - I can access the drives contents on windows/network explorer and I can access the NAS's control page. However, I want to use the drive to store video from my security cameras. This requires the comera to connect with the NAS' IP address. However, the only IP address I have is that of the WNCE2001.
Any way to access the IP address of the drive itself so that the cameras can connect to it?
If you can access the NAS's control page, then look around on the NAS and see if there's a page that shows its IP address.
- sktn77aVirtuoso
OK, thanks. I just tried that. The WNCE2001 IP address is 192.168.1.37 and the NAS's internal IP address is 192.1681.14. When I direct the cameras to 192.1681.14, they just say NAS access failed (same as when I direct them to 192.168.1.34). I don't think this is going to work but if there are any other ideas out there, I'm all ears.
What method is being used by the cameras to access the NAS? SMB (aka Windows file sharing)? FTP? Something else?
Is that method of access enabled on your NAS?
