JRn900's avatar
JRn900
WNCE4004 cannot connect to Cisco XB3 from Xfinity
Just got new Comcast Router - Cisco XB3 and cannot connect thru the Genie software. Gets to the last part of setup and says move unit closer to router.Is there something I'm missing? Is this n900 4004 Wireless Adapter not compatible with this Comcast router? Firmware version is V1.0.0.22
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi JRn900,
    1. How far is the WNCE4004 from the router?
    2. Make sure that the router does not have MAC filtering. If you are not sure, check with the manufacturer.
    3. Reset the adapter and reconfigure.
    JamesGL
    Community Team
    • JRn900's avatar
      JRn900
      Adapter is in same location as it was with previous Comcast router. Not sure how to check MAC filtering on router. It appears to connect with the router momentarily but drops at the end of the process.
      • JamesGL's avatar
        JamesGL
        Hi JRn900,
        Check with router's manufacturer and make sure that MAC filtering is not enabled. Try to lower down as well the security of the wireless network and change channel.
        JamesGL
        Community Team
