hassaninho
Nov 10, 2019Aspirant
5ghz wrong channel
I am very disappointed of this product. I have tested everything.
My 5Ghz is not working because the extender is giving the channels between 100 and 140.
My devices can't support that.
I have testet everything and I have latest fireware.
I can't change it manually to 36.
My router channel is 36.. But the extender does not follow my router.
Please help
Please help
Are you running in access point mode or in extender mode?
Are those channels grayed out or whats preventing the change?
What is the latest firmware you're using? A number is better than "the latest"
Which region are you in? and which region is your router and extender set to?
- hassaninhoAspirant1. Extender Mode.
2. No, they are not even on the list of 5ghz. I can only choose 100 to 140 on that list.
My routers channel for 5ghz is 36 but the netgear extender change it to 100 - 140
3. 1.0.0.52
4. Europe- plemansGuru - Experienced User
For testing, if you enable access point mode (direct wire it), are you able to choose 32-48?
What do you mean that your extender changes it to 100-140? It changes your primary router's broadcast channel?
