nathalia
Jan 30, 2019Aspirant
AC 1900 WiFi Range Extender EX7000
the extender seamed to never have worked as good as i hoped, but lately i can't even access the extender itself through the webbrowser.
i got an email, that said, i needed to download an important update, but i can't access it, not even through ethernet cabel.
any help on how i can update my extender?
thanks!
- Christian_RNETGEAR Employee Retired
Hi nathalia,
Hard reset the extender and join the NETGEAR_EXT wifi network. After you connect to it, you'll be able to browse to www.mywifiext.net and update the firmware.
~Christian
- nathaliaAspirant
Thanks Christian,
Hard reset, you mean the little pin hole, right? i did that and then reconnected the extender with the router. i still can't access it?! not sure why
Hello nathalia,
When you hard reset the extender are you able to locate the wifi network named "NETGEAR_EXT" using a laptop or mobile device?~Christian
Hi nathalia - You can try logging into your router's admin page and locating the extender under the router's attached devices list. Once you identify your extender, there will be an IP address you can use to enter in a web browser eg. 192.168.1.x. Enter in the IP address shown and you should be prompted to log into the extender's admin page.
~Christian
