Ironmonger's avatar
Sep 10, 2020
Appalling Support
Hi,
Has anyone else experienced the same level of appalling customer support that I’m enduring in trying to replace a faulty extender?
I bought an EX7700 on 19 Aug. That device caused anything connected to it to show full WiFi signal but blocked them from connecting to the internet. In trying to troubleshoot it, the support agent asked me to do a factory reset and firmware update, which failed and bricked the device.
I was then threatened with a £20 charge to cover the postage to replace it, which I challenged and was got assurance would be refunded.
The replacement extender arrived and has had a different issue since I first plugged it in. This one kicks any device connected to it off the network and causes an error message saying the network key is wrong, which it patently is not.
I have now spent nearly 6 hours on the phone trying to resolve this.
Yesterday I was told that if a factory reset didn’t fix it I would be sent another replacement. The issues remain so I contacted support to request said replacement, only to be told nothing exists on my records to show that promise and that I would need to do more troubleshooting.
On top of this I’ve had multiple calls cut off, with support agents seemingly unable to call me back despite them confirming my number and country code. I’ve also had multiple cases closed when issues still exist, one time after the system failed to accept an update.
Oh, and the app issues incorrect firmware update status and requirements during installation.
Am I the only person who has suffered in this way?
All I want is a working extender but, after 2 devices, 3 weeks and nearly 6 hours on the phone that seems like an unachievable ambition.
I’ve sent a message to customer support but, perhaps unsurprisingly, I’ve heard nothing back.
I realise that the world is a very difficult place right now and I really am trying to be patient and understanding. But this situation is completely unworkable.
If anyone out there has any suggestions at all, I’d be more than grateful to receive them.
Sorry for the rant but I have no idea what else to do right now.
    • Ironmonger's avatar
      Ironmonger
      Tutor
      Hi David,
      I am in the UK and have a Virgin Media Hub 3 router.
      In terms of firmware, it’s on .210. How do I take it back to .206? Also, given the service I’ve had from support, I’m not sure I’m comfortable doing that without them suggesting it; my fear is it bricks the device as the last firmware update did and they say it’s my fault.
      And with regard to WPS, I’m not sure that’s a problem. The extender does see the network itself, and does connect itself to the network. It then pushes out that network to other devices but that’s when I hit the password problem.
      Thank you, though, for taking the time to reply. If there’s anything else you can think of, I’m all ears!
      Ironmonger
      Tutor
      But I will post that firmware rollback as an update to my case and see what they say.
      Thank you
  • plemans's avatar
    What router are you connecting it to?
    What firmware is on the extender?
    Are you attempting to set it up using the wps method?
