Kort2127's avatar
Kort2127
Does ex6120 work to extend google fiber?
I have been searching a bunch of sites for info and some say yes, and others no.  Please advise before I waste more time trying to configure.  I'm not the best with this stuff and quite frankly, I'm not totally excited about our google fiber service but I'd love to extend it so we can get it in other areas of the house before I go back to ATT.
Thanks in advance,
Kortney
  • StephenB's avatar
    It should be able to extend any reasonably modern wifi network.
    What are you using for your router?
    • Kort2127's avatar
      Kort2127
      It's the google fiber router and doesn't support WPS
      • StephenB's avatar
        You don't need to use WPS to set up the extender. So that is not an issue.
        Do you know if it is the GFRG110 or the GFRG100?
