helpmeireally
Dec 31, 2018Aspirant
ethernet to internet extender not recognized READ DESCRIPTION PLEASE!!!!
So i bought this internet extender two years ago and i have been using it wirelessly with an internet extender on my computer. However when i plug in my ethernet cable into the internet extender it d...
helpmeireally
yes it is a wifi usb adapter, the manufacturer is MSRM and the model number is WA926. i've been using this to connect to my new wifi wirelessly but when i plug in my ethernet to my extender it connects to my old wifi
Dec 31, 2018Guru - Experienced User
Just to be clear - is the ethernet going between the PC and the extender.
- helpmeireallyJan 02, 2019Aspirant
Yes sorry for not responding right away!
- StephenBJan 02, 2019Guru - Experienced User
Ok. So why are you using the WiFi USB adapter in the PC if the PC is connected via ethernet to the extender?
If you remove the WiFi USB adapter, are you able to reach the internet from the PC?
No, I used to have a wifi usb adapter which was connected to the new internet that i use now, i then replaced it with an ethernet cord but that connects to my old internet that i used before. I'm trying to figure out a way to connect to my new internet using the ethernet cable connected between my pc and internet extender
