helpmeireally
Dec 31, 2018Aspirant
ethernet to internet extender not recognized READ DESCRIPTION PLEASE!!!!
So i bought this internet extender two years ago and i have been using it wirelessly with an internet extender on my computer. However when i plug in my ethernet cable into the internet extender it d...
Jan 04, 2019Guru - Experienced User
Are you able to reach the internet from your PC?
The PC should only be seeing an ethernet connection (unless it has another wifi radio enabled, or if you left the wireless adapter installed). The name Windows gives to that connection doesn't matter.
helpmeireally
Jan 05, 2019Aspirant
Yes I am able too. And wait it doesn't matter ? cause i just thought it was weird that connecting my computer to the wireless extender via ethernet should connect to the new wifi and not the old one. Would you want me to send a screen recording of my pc of whats going on ?
- StephenBJan 11, 2019Guru - Experienced User
Again, the PC shouldn't be using WiFi at all. It should just be using ethernet.
If you are running Windows 10, try looking at the network status page (enter "network status" in the taskbar search bar). You should be seeing a screen that looks something like the one below. You can post your own screen shot (or video) if you like.
