MutantPike
Sep 26, 2016Follower
EX2700 – N300 WiFi Range Extender cannoct connect to router at all.
Hello, I bought this WiFi extender modem, recently. I have a big problem with setting this up, I was trying all the options possible, I searched the forum through for the answer however I did not f...
DarrenM
Sep 28, 2016Sr. NETGEAR Moderator
Hello Mutantpike
Make sure your main router is using WPA2 security after that factory reset the Ex2700 by holding the reset button for 10 seconds then try the setup again.
DarrenM
