icelandd
Oct 09, 2016Aspirant
EX3700 incorrect password
i just got my range extender and conected it to the router with wps.... i did it twice because the router has 2 and 5 ghz.....
i now see the new wifi...
2GEXT and 5GEXT but when i try to connect it always says: Incorrect password. i am 100% sure i am using the right password....why is it doing this ???
- DarrenMSr. NETGEAR Moderator
Hello icelandd
Have you tried using your main routers password? if thats not working you may have to do a factory reset and do the setup again.
DarrenM
