TheBogeyMan's avatar
Jul 20, 2017
EX6120 - no network connection on 5GHz
Installed and configured my.EX6120-100NAS. During config phase all was good - picked up both 5GHz and 2.4GHZ networks.
But when it restarts it will only provide a network connection on the 2.4 network. If I connect to the 5G network I get no DHCP address.
I have verified that it's not my main router - if I connect directly to the 5G network, everything is fine.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello TheBogeyMan
    You could try to factory reset the unit and set it up again see if the 5ghz comes back.
    DarrenM
    • TheBogeyMan's avatar
      TheBogeyMan
      Tutor
      I could. I did. Multiple times before I posted this. The 5G never "went away". It just won't connect and get a connection.
      I set up the unit while next to the router. Same deal.
      I set up the unit while in the location where it needs to be placed. Same issue.
      I did this at least 4 times.
      As I said, during the config phase, it is able to pick up both the 5G & 2.4G networks (with a signal strength of 100% on both bands).
      Unless I exclude the the 5G band it does not pick up a network when it restarts and does not assign the connected device a DCHP-assigned IP address.
      • DarrenM's avatar
        DarrenM
        Hello TheBogeyMan
        Have you tried to lower the wireless channel on the 5ghz network on the main router?
        DarrenM
