Kat123
Jan 27, 2017Follower
EX6200 - cannot get internet connection via wifi
Hi - we upgraded to the BTHub6, and now our EX6200 wont allow us to connect to it via wifi We can see the extender in the BT home hub admin console, but cannot change any details (e.g. static IP is ...
DarrenM
Feb 01, 2017Sr. NETGEAR Moderator
Hello Kat123
You will need to factory reset the extender by holding the reset button for 10 seconds on the device you then can setup the extender for the new modem.
DarrenM
MarkNYC
Mar 14, 2017Initiate
Hi - I have the same problem and have reset the extender as well as the extender setup multiple times. When I turn the extender on, the interenet works for awhile then goes dead. Laptop can still see the extender network (very strong) but internet access is not possible. So, I can keep turning the extender off then on, but this doesn't seem to be optimal. Are there certain settings on the model/router combo that might help here?
Please advise.
