RALLYINGLES
Jun 16, 2016Follower
EX6200 Wireless Extender
I am not able to access using Genie, all I do is get errors messages in relationship to IPV6 which I have enabled, not certain how to desable it, using the EX6200 with a ARRIS Cable modem on Comcast,...
DarrenM
Jun 27, 2016Sr. NETGEAR Moderator
Hello Rallyingles
Have you been able to access the extender using www.mywifiext.net ? You may also want to directly connect a pc via ethernet to see if you are able to log into the extender. Is your main issues being able to access your USB drives or not getting any internet connection or both?
DarrenM
