NX's avatar
NX
Initiate
Sep 15, 2016
EX7300 drops internet connectivity
Hi there,
so I purchased myself an EX7300. Manual setup went all well.
My problem is, that, although Windows states that it has internet access and and the wireless signal is at the highest level, my internet connection is lost every few minutes. I have to disable/enable the WLAN connection to regain internet access, but again, it's just for a short period.
When doing a Windows troubleshooting, the message is: Windows can't communicate with the device or resource (Primary DNS server) [primary DNS server is 192.168.0.1]
The extender has a static IP which is 192.168.0.50, but the router gives it a DHCP IP which is 192.168.0.106.
Firmware is the latest: 1.0.0.44
This is truly annoying and it renders the extender totally useless.
Any suggestions?
Thank you
NX
Diagnostics Information (Network Adapter)
Details about network adapter diagnosis:
Network adapter Wi-Fi driver information:
Description . . . . . . . . . . : Broadcom 802.11ac Network Adapter
Manufacturer . . . . . . . . . : Broadcom
Provider . . . . . . . . . . . : Broadcom
Version . . . . . . . . . . . : 7.35.338.0
Inf File Name . . . . . . . . . : C:\WINDOWS\INF\oem22.inf
Inf File Date . . . . . . . . . : Tuesday, December 22, 2015 7:40:16 AM
Section Name . . . . . . . . . : BCM43XAC_NT64
Hardware ID . . . . . . . . . . : pci\ven_14e4&dev_43a0
Instance Status Flags . . . . . : 0x180200a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 71
Physical Media Type . . . . . . : 9
InformationalDiagnostics Information (Wireless Connectivity)
Details about wireless connectivity diagnosis:
Information for connection being diagnosed
Interface GUID: a13d5586-ed7e-45c7-8f79-83a8e94543b1
Interface name: Broadcom 802.11ac Network Adapter
Interface type: Native Wi-Fi
Connection incident diagnosed
Auto Configuration ID: 3
Connection ID: 2
Connection status summary
Connection started at: 2016-09-15 23:39:11-840
Profile match: Success
Pre-Association: Success
Security and Authentication: Success
List of visible access point(s): 3 item(s) total, 3 item(s) displayed
BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
B0-7F-B9-FF-79-21 Infra <unknown> -57 5180000 Netgear_EXT
34-31-C4-82-5E-16 Infra <unknown> -69 5180000 FRITZ!Box Fon WLAN 7390
20-0C-C8-28-12-A2 Infra <unknown> -59 5220000 UPC247320857_5GEXT
Connection History
Information for Auto Configuration ID 3
List of visible networks: 3 item(s) total, 3 item(s) displayed
BSS Type PHY Security Signal(RSSI) Compatible SSID
Infra <unknown> Yes 80 Yes Netgear_EXT
Infra <unknown> Yes 50 Yes FRITZ!Box Fon WLAN 7390
Infra <unknown> Yes 78 Yes UPC247320857_5GEXT
List of preferred networks: 2 item(s)
Profile: Netgear_EXT
SSID: Netgear_EXT
SSID length: 16
Connection mode: Infra
Security: Yes
Set by group policy: No
Connect even if network is not broadcasting: No
Connectable: Yes
Profile: Empire21-5GHz
SSID: Empire21-5GHz
SSID length: 13
Security: Yes
Connectable: No
Reason: 0x00028001
Information for Connection ID 2
SSID: Netgear_EXT
SSID length: 16
Security: Yes
Pre-Association and Association
Connectivity settings provided by hardware manufacturer (IHV): No
Security settings provided by hardware manufacturer (IHV): No
Profile matches network requirements: Success
Pre-association status: Success
Association status: Success
Last AP: b0-7f-b9-ff-79-21
Configured security type: WPA2-PSK
Configured encryption type: CCMP(AES)
802.1X protocol: No
Key exchange initiated: Yes
Unicast key received: Yes
Multicast key received: Yes
Number of security packets received: 0
Number of security packets sent: 0
Security attempt status: Success
Connectivity
Packet statistics
Ndis Rx: 3206809
Ndis Tx: 4555633
Unicast decrypt success: 16225
Multicast decrypt success: 0
Unicast decrypt failure: 0
Multicast decrypt failure: 0
Rx success: 16646
Rx failure: 23427
Tx success: 35407
Tx failure: 0
Tx retry: 3
Tx multiple retry: 2
Tx max lifetime exceeded: 0
Tx ACK failure: 7
Roaming history: 0 item(s)
Information for Auto Configuration ID 2
List of visible networks: 6 item(s) total, 6 item(s) displayed
Infra <unknown> Yes 82 Yes FRITZ!Box Fon WLAN 7390
Infra <unknown> Yes 90 Yes UPC247320857_2GEXT
Infra <unknown> Yes 50 Yes (Unnamed Network)
Infra <unknown> Yes 60 Yes (Unnamed Network)
Infra <unknown> Yes 81 Yes (Unnamed Network)
SSID: Netgear_EXT
SSID length: 16
Security: Yes
Connectable: No
Reason: 0x00028002
SSID: Empire21-5GHz
SSID length: 13
Security: Yes
Connectable: No
Reason: 0x00028001
Information for Auto Configuration ID 1
List of visible networks: 1 item(s) total, 1 item(s) displayed
Infra <unknown> Yes 100 Yes Netgear_EXT
SSID: Netgear_EXT
SSID length: 16
Security: Yes
Connectable: Yes
SSID: Empire21-5GHz
SSID length: 13
Security: Yes
Connectable: No
Reason: 0x00028001
Information for Connection ID 1
Connection started at: 2016-09-15 23:35:10-026
Auto Configuration ID: 1
SSID: Netgear_EXT
SSID length: 16
Security: Yes
802.1X protocol: No
Connectivity
Packet statistics
Ndis Rx: 0
Ndis Tx: 0
Unicast decrypt success: 27803
Rx success: 28733
Rx failure: 32644
Tx success: 60353
Tx failure: 0
Tx retry: 0
Tx multiple retry: 0
Tx ACK failure: 0
Roaming history: 1 item(s)
Times: 2016-09-15 23:37:51-119
Roamed from BSSID: b0-7f-b9-ff-79-21
Reason: 0x00000002
Disconnected from BSSID: 00-00-00-00-00-00 Reason: 0x00000205
For complete information about this session see the wireless connectivity information event.
Helper Class: Auto Configuration
Initialize status: Success
Result of diagnosis: There may be problem
InformationalDiagnostics Information (Wireless Network Adapter)
Details about wireless network adapter diagnosis:
Helper Class: Native Wi-Fi MSM
SSID: Netgear_EXT
SSID length: 16
Security: Yes
Connect even if network is not broadcasting: Yes
InformationalNetwork Diagnostics Log
File Name: 66CE1D78-4637-45F3-B515-EEEDE06E8354.Diagnose.0.etl
InformationalOther Networking Configuration and Logs
File Name: NetworkConfiguration.cab
Collection information
Computer Name: PRIVATE
Windows Version: 10.0
Architecture: x64
Time: Friday, 16. September 2016 00:35:20
Publisher details Expand
Windows Network Diagnostics
Detects problems with network connectivity.
Package Version: 3.0
Publisher: Microsoft Windows
  • I think I solved the problem by giving the router a fixed wLAN channel (48) and the repeater another (40). Haven't had this issue since.
    • Noobie's avatar
      Noobie
      I've been having the similar issues (same model, same firmware version).  I've modified the settings so that router and extender have different channel numbers.  Hope this works for me as well.
      When I called NETGEAR support, they've asked me downgrade the firmware to the initial release.. Rather than downgrading the firmware, I came to this site, and found your message.  Thanks for posting your details.
      • agassner's avatar
        agassner
        I have the same issue with the same model and firmware and can't find the solution!
        I don't have the option to change the WiFi Channel.
        Help!
  • I see the same thing happening on my router as well.  The extender is set to be a static IP but the router shows it as a dynamic IP.  This is one of the issues I have been having.  The rest you can read under the topic R7800 and EX7300 network issues.
