19216811's avatar
19216811
Initiate
Dec 22, 2016
How to get access to 192.168.1.1?
If you enter 192.168.l.l to http://192.168.1.1  modem router administrator password & login IP addresses. 192.168.1.1 IP addresses is the address of your ADSL modem administration panel. All the manufacturers of modems provides a latest software in their modems for its easy and  user friendly management. The software that is installed on the modem provides you various features including configuring the new settings, customizing other important options. Whenever any issue is rised with the connection, it can be easily resolved  through its management panel.
Router default password for www.19216811.kim
  • Follow these Simple Steps for 192.168.1.1 Login through the Gateway which gives access to Configure and Change Settings of your WiFi Router.
    • Enter Official Site  192.168.1.1 or http://192.168.1.1 in any of your Browser (IE, Firefox, Google Chrome, Safari).
    • If the Login Page is Not Opening, then 19216811 is not your Router’s Default IP Address. Refer this Article to Find Default Router IP Address.
    • Once you Found the Correct IP Address, Insert the same into your Web Browser Address Bar.
    • You’ll be Forwarded to Login Panel which asks for Username and Password to Sign In. Check out Default Username and Password.
    • Follow this Guide if you Forgot Username and Password of your Router.
    • Put down the Credentials and you’re in. Refer to FAQ’s, If you have any Issues.
    • leoliang's avatar
      leoliang
      192.168.1.1 is the default login path of many routers, some of which are 192.168.0.1. The login paths of different models are different. For example, I have tp link archer ax90 and the default login path is 192.168.1.1. If you use netgear router maybe the same or maybe different.
  • I have mentioned some simple steps to access 192.168.1.1 below, you can try these steps.
    • Hit enter button and 192.168.l.l admin page loads in few seconds.
    • If the page didn’t load, then your router’s login ip address is differect. (Find Router IP Address)
    • Provide Username and Password details of your Wifi router.
    • Generally, you can Find Default Router Username and Password details provided backside of router or router package box.
    • Once you login, WIFI admin panel appears where you can make changes of router configuration.
    • If in case you changed the default username/password details, follow the below instructions which will guide you to recover them quickly.
    More Information : 192.168.1.1 Admin login – 192.168.l.l Reset Router Username & Password
    • routerwi's avatar
      routerwi
      Initiate
      you can get help from 192.168.l.l.mobi web site. There is a lot of quality information for router access panell.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    This should log you into your router I am not really sure what issue you are having can you explain?
    DarrenM
