Mauricey
Aug 29, 2016Aspirant
My iPhone connects to my extender but doesn't switch to home wifi when I change rooms!
Hi everyone! Minor problem really but kind of bugging... I have set up my extender in my flat and it works fine - I can now access wifi from the loo ;-) BUT... as I move around my home, I fi...
DarrenM
Aug 31, 2016Sr. NETGEAR Moderator
Hello Mauricey
That is how the extender works no real way to fix that issue it will hold onto the signal until it is out of range of the extender fully or you switch on your own. We are launching a product called orbi that will do what you are wanting you may want to check it out.
http://www.netgear.com/home/products/networking/orbi/?cid=wmt_netgear_organic
DarrenM
- MauriceySep 02, 2016Aspirant
OK, thanks for taking time to reply, Darren - I'll check it out!
