darkmatter661's avatar
Mar 13, 2017
N300 Extender does not see Sonicwall TZ300
I have a Sonicwall TZ300 with internet working fine in 2.4Ghz in n/g/b mixed mode.  I'm trying to extend it with an N300 which used to work just fine on a TZ100.  However, the N300 does not see the SSID of the TZ300, which is not hiding its SSID.  I've tried bringing it closer to the Sonicwall with no better results.  Any ideas?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello darkmatter661
    Is the new router a 5ghz signal? the n300 is 2.4ghz only.
    DarrenM
      • DarrenM's avatar
        DarrenM
        Hello darkmatter661
        Have you tried to factory reset the extender and try setup again?
        DarrenM
