Rufi34's avatar
Rufi34
NETGEAR EX7000 Connection Problems
Hello Guys,
i have a big issue with my Range Extender* ( EX7000). (I'm connected to the 2GEXT.)
The problem is that my Labtop, Computer connects fine to the RE* ... but my other devices like my PS4, Iphone , IPad have Problems with the Connection.
I solved the Problem on the I/phone/pad by typing the CLIENT-ID manually in the WLAN Settings from the RE.
But on the PS4 i can't connect to the RE. I tested it via LAN and WLAN Connection.. FAILED.. But when i connect to the main WIFI Connection everything works fine..
Also tried to reset the RE Device.. same result. I also have Problems to connect on http://mywifiext.net/. My Internet explorer tells me ERR_CONNECTION_TIMED_OUT while i'm connected to the RE Device...
Can anybody help me or have the same Problem with the RE EX7000 ?
Thanks
Rufii
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello rufi34
    Have you tried to reserve the IP of the extender and the PS4?
    DarrenM
    • Rufi34's avatar
      Rufi34
      Hello DarrenM,
      thanks for your reply :)
      Sorry how can i do that ? Do i have to do this in my Main Router settings or on the Range extender ?
      Greetings
      Rufi
      • DarrenM's avatar
        DarrenM
        Hello Rufi34
        That would be on the main router.
        DarrenM
