tz10uk's avatar
tz10uk
Nighthawk X10 Create a mesh with the same SSID with 2 EX8000
Hi
I have a R9000 (5D82855V003DB) router running off a Virgin Media router set as a modem, this router has a SSID as wifi is a real issue in my house and power lines dont work, I purchase 2 EX8000 that now have separate SSID I wanted to set the mesh up so that they all have the same SSID but when I set them up the network drops and I loose all WIFI connectivity
Any ideas on configuration for the router and extenders to prevent WIFI drop outs but have the same SSID throughout the house - the multiple SSID seems to work but means I need to change each time I leave a strong signal
I have tried using the setting on the devices but had to factory reset and have a different SSID
Thanks
T
  • tz10uk wrote:
    do you recomend a channel for the 2 GHz I have multiple other routers so clashing
    There are some apps out there that can look for interference, and help you select a reasonable channel.
    But you could just set it to use the channel it's selected now.
    You might also try setting the 5 Ghz channel to the highest channel number on the list, and see if that is more stable.
    • tz10uk's avatar
      tz10uk
      Hi thanks for your reply
      No it drops out just very odd
      T
      • StephenB's avatar
        What firmware is running in the EX8000s?
        Are the R9000 radios set to "auto"?  If so, perhaps try setting them to fixed channels.
