Kirkruns1's avatar
Mar 06, 2016
Problem setting up WNR614 as Wifi Repeater / Range Extender
I recently had to reset my r7000 nighthawk router - when I did the extender won't connect - I have tried with both an ethernet cable and mywifiext.net.  Other suggestions?
  • Did you do a factory reset of your R7000?  If so, the reset will have reverted the R7000 to its factory configured Wi-Fi settings.  You will need to change the Wi-Fi settings to whatever they were before the reset.  Once you do that, the extender should work.  Or else change the extender to work with the new Wi-Fi settings.
    • Kirkruns1's avatar
      Kirkruns1
      Tutor
      I did reset to factory - but mywifiext.net will not pick up the new or old settings on the extender?
      • TheEther's avatar
        TheEther
        Guru
        Can you confirm that you reset the R7000 to factory defaults?
        I didn't understand what did you meant by "mywifiext.net will not pick up the new or old settings on the extender".  Visiting mywifiext.net will not cause the extender to automatically pick up the R7000's Wi-Fi settings.
        If you have WPS enabled on the R7000, then you can use it to transfer the Wi-Fi settings to the extender, but that's different than visiting mywifiext.net.
        Can you clarify what you tried to do?
