S1DIMMER
Jun 08, 2014Aspirant
R7000 Nighthawk wired to EX6200?
I just purchased the R7000 Nighthawk router and while the speed increase has been fantastic the range has not been great. Setup was simple, I installed it in my basement where my old DLINK N router was and got everything working great then discovered the signal died when I go up to the second floor of my house. So I'm looking for an extender to put up on my second floor. I found the EX6200 which seems to be the best netgear has to offer right now. I want the best possible signal from the R7000 to the EX6200. So can I just connect the two with an ethernet cable from a LAN port on each rather than try to use a wireless connection between the two? I already have an ethernet cable run to the second floor. I was thinking that'd be better than using wireless to connect the two units. Thanks for your help.
- Retired_MemberYou need to get it out of the basement. Forget the antennas unless you're getting a set for the clients as well.
- jmizoguchiVirtuosoYou are in the bad place... You do not want to any more that -50 reading on signals.
Place the router in the first floor would more suitable and place another extender and spend more money. If broadband modem is located in the basement and can not move then try find the way to run ethernet cable to the first floor. - S1DIMMERAspirantSo I think the original error I made was trying to hook up all my N devices to the 5Ghz band instead of using the 2.4Ghz band. 2.4Ghz seems to have way better signal strength. So I have the R7000 hooked up as an access point in my second floor office and I went around the house and took signal strength readings in a bunch of rooms on each floor and came up with an average signal strength:
2.4 5 old Dlink N
AVG 2ND FL 34 46 58
AVG 1ST FL 44 65 63
AVG BASEMENT 49 74 41
I may try the R7000 as an access point on the first floor and redo the signal readings. Probably not tonight as it's late now. Thanks again. - S1DIMMERAspirantSo I moved the router to the first floor and it's working reasonably well. I have a usable signal all over the house, at least on the 2.4Ghz band. Second floor also worked but seems a shame to spend the money for this router then use it as just an access point. So I'm going to pickup some higher gain antenna and try it again in my basement replacing my DLINK router. If that doesn't work I may just put it back in my office on the second floor and keep the DLINK in place as the main router. In the future I'll remember to run at least 2 cat 5e or cat 6 cables to each room instead of just one.
- jmizoguchiVirtuosoPlacing the router at top or bottom floor or adjacent from where you want active is never a good. Centrally located is always the better results as you seen when placed in first floor to cover 2nd and ground floor.
