ped
Mar 18, 2016Aspirant
Wifi Extender Limited Number of Connections, Devices Dropping, EX6200
So I currently have my EX6200 setup with my cable provider router. I have 2 issues: 1.) I was able to achieve, using the smart setup (2.5GHz to router, 5GHz with devices) get something like ...
ped
Apr 05, 2016Aspirant
Thanks for the reply.
I actually found answers in 2 other threads that I didn't find when searching on this site directly nor google. Ironicially creating this case then created a "recommended / similar" cases on the right that I then utilized. First I followed this solution:
And after resetting both the modem and the extender - seemed to work for about 1.5 weeks. However the problem is now back with the devices not connecting anymore.
So now I'm going to follow the recommendation of a thread I found through that same method, and now I cannot anymore because the recommended cases are not the same. :( Anyway it was similar to what you are recommending, like this thread:
So as of now my problem is still not solved. I have a feeling it's related to this latest firmware, so downgrading to .98 - what I had before - will eliminate both issues.
Crossing my fingers!
ped
Well I just did the downgrade to .98, and my devices connected immediately. So although happy, not entirely going to count my chickens before they hatch yet.
Will monitor this for another 2 weeks, and if it stays stable - will consider it closed.
Thanks again for the reply!
