Hcholm
Mar 17, 2016Aspirant
WN1000RP won't connect to router at all
Hi everyone, I am having real trouble trying to set up my WN1000RP extender. I have tried everything in the set up guide but I cannot get it to connect to the router. It's not a proximity issue b...
Hcholm
Also, when I go into the wizard/IP address option again from my iPhone while connected to the _EXT network neither the orginal, nor the new _EXT network show up in the list of those available.
The network information for the _EXT network shows on my iPhone but not any other device when it is selected if that also helps the diagnosis??
- DarrenMMar 29, 2016Sr. NETGEAR Moderator
Hello hcholm
Have you tried to connect the extender by using the WPS button? you will want to hold it down for 10 seconds on the extender and have wps active on your router.
DarrenM
