Geforce's avatar
Geforce
Novice
May 09, 2013
WNDAP350 & 2 x ANT2407
Hi,
I've set up and purchased 1 x WNDAP350 and 2 x ANT2407 Antenna's but with poor results it seems.
I've enabled external antennas in the 2.4Ghz range, but it doesn't seem to make an awful lot of difference compared to the internal 5Ghz antenna.
At the moment, I'm sat maybe 2 feet from the WNDAP350 and 2 feet also from a standard ISP router and the standard ISP router says ~93% on my wifi scanning tool, but the WNDAP350 is sat at around ~86% on the 2.4Ghz Anntenas but ~90% on the 5Ghz antenna?
If I walk down the office approx 25 feet away with no obstructions, I get:
Standard ISP router ~70%
2.4Ghz Antenna ~65%
5Ghz Antenna ~68%
If I go outside, which is 20ft down and 30ft across the car park, I get:
Standard ISP router ~21%
2.4Ghz Antenna ~16% :confused::confused:
5Ghz Antenna ~21%
To me it looks like the antennas are not functioning correctly - or I've not set them up properly. Any ideas?
