RocketmanSFCA
Feb 01, 2024Aspirant
AC1750 6400v2 Dual Band WiFi Router - unreliable 2.4Ghz connection
I've been using the Netgear AC1750 6400v2 dual band wifi router at home for about a year without issue. But recently, I cannot access the internet over the 2.4Ghz band. I have no issues connecting to the router over that band and staying connected from multiple devices, but those devices then have unreliable internet access. This is true whether I am immediately next to the router, farther away in the house, or trying to connect via Netgear wifi extenders. This is true for all 4 members of my family accessing the internet from their multiple devices. Total device count peaks at 14 devices.
I have no issues connecting to the 5Ghz band or to the internet through the 5Ghz band.
I've reviewed multiple posts about other wifi products, and have tried rebooting the cable model (not from Netgear), rebooting the wifi router, and resetting the wifi router to factory settings. None of that has worked.
I probably wouldn't care much because most of our devices can connect over 5Ghz band; however, we now own 3 security cameras that only connect over the 2.4Ghz network. And while that was working for several months, the poor connection now prevents them from working effectively.
Suggestions?
Thanks.
You can try changing the channel the 2.4ghz is on. 2.4ghz is more sensitive to interference than 5ghz which can cause issues. Channel changes might help and is worth
What's the firmware on the R6400v2?
- RocketmanSFCAAspirant
Hi, thanks for asking the firmware version question. The router's firmware was not up-to-date; I had tried updating it via the Nighthawk app during WiFi network setup, but received a few error messages so skipped it at the time.
But given your question, I managed to upgrade the firmware 'manually' without the app. It's now running V1.0.4.128_10.0.104, which I believe is the latest.Unfortunately, that didn't solve my issue: I can connect to the 2.5G WiFi network band, but I immediately ran into download rate issues.
I'm now going to try the next suggestion on this thread: manually setting a channel instead of relying on the auto feature.
What modem/ONT/gateway sits between the router and the Internet?
