  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi rungel,
    Using the latest firmware should correct any issues like this.
    Do you have the latest firmware installed on your router?
    Here's a link on how to upgrade the firmware.
    In addition to this Avast vulnerability, kindly see this thread.
    • rungel's avatar
      rungel
      Tutor
      Hi ElaineM,
       I did have that version installed, but went ahead and flash it again. But Avast still tells me the same issue is there.
      • mediatrek's avatar
        mediatrek
        Virtuoso
        Per Netgear's EOL (end of life) product policy, they will have long since stopped support for the WNDR3800 with anymore firmware updates; even if there are security holes in the firmware. Basically you have to go out and buy a newer model router. Netgear will not be fixing it. The end.
