JohnFairfax
Apr 25, 2018Aspirant
Cannot access my router settings (log-in) in any way (factory reset'd several times)
Hey everyone, before I start I want to apologize if this is not the correct section to post this thread.
The router I currently own is this one (click here) and I simply cannot access my router...
- Apr 26, 2018
> The router I currently own is this one (click here) [...]
Why not simply type the model number?
> [...] all the login infos I've looked up in google won't work. [...]
That non-description conveys no useful information to the
non-psychics in your audience.
> [...] I got a message saying "Your conenction is not secure" [...]
That's normal when using "http://" (not "https://") with a modern Web
browser. And what did you do then? Continue? Quit?
> [...] [My ISP provided me this Netgeat router, I didn't buy it by
> myself]. [...]
If the router is running ISP-specific firmware, then the usual
Netgear (retail-router) default credentials might not work. In that
case, your ISP might be the best source of information on it.
> [...] After factory reset I got the default SSID and PW of the
> network, [...] I'm stuck with a SSID called "SureWest-f1" instead of
> the custom SSID I want.
If the settings reset gave you a default SSID of "SureWestXXX", and
not "NETGEARxxx", then it sure looks to me like ISP-specific firmware.
Regarding SureWest, I know nothing, but a quick Web search for keywords
like, say:
surewest router password
might find more relevant information than you'll get from a pure Netgear
source. For example:
https://tpsconsulting.blogspot.com/2014/12/consolidated-communications-cci-router.html
which suggests "admin" and "cciadmin".
> [...] I'm looking to change my router's MAC Address [...]
That could be possible if you could get into the router's
administration web site.
antinode
Apr 26, 2018Guru
> myself]. [...]
like, say:
JohnFairfax
Apr 26, 2018Aspirant
Thank you very much, this was it!
This was confusing because the guy initially gave me "SWAdmin" and password "$WN3Tw0rK!"
Who would've known that, thanks antinode.
