firozp's avatar
firozp
cannot find wireless repeating function in my D1500's console settings
Hi,
I am trying to enable the wireless repeating function on my D1500 router. As per the instructions there should be an option called "Wireless Repeating Function"
in the advanced settings of the admin console page. This option is not shown for my router !
Does anyone know if this option is only supported by some specific variant of D1500s ?
Thanks in advance :)
  • firozp's avatar
    firozp
    Jul 17, 2018
    Weirdly i the option showed up after downgrading to the firmware version: D1500_V1.0.0.15 and it works perfectly :smileyhappy:
    Not sure why it was removed in the newer versions.
    Thanks for your time anyway antinode
  • > I am trying to enable the wireless repeating function on my D1500
    > router. [...]
       Firmware version?
    > [...] As per the instructions there should be an option called
    > "Wireless Repeating Function" in the advanced settings of the admin
    > console page. [...]
       "As per" which "the instructions"?  I see it in a picture in the User
    Manual, but not in the text.  I'd guess bad documentation (and/or
    firmware changes over time).
       My D7000 (V1.0.1.64_1.0.1) doesn't have it, either, but that agrees
    with its docs.
    • firozp's avatar
      firozp
      Hello antiNode,
      Really appreciate the quick response !
      Firmware version is V1.0.0.27_1.0.1PE
      I have attached a screenshot of the console.
      I read about the function in the online FAQ at https://kb.netgear.com/26900/D1500-FAQ-s (section Can D1500 act as a repeater?)
      • antinode's avatar
        antinode
        Guru
           That all looks reasonable, unless you expect reality to agree with
        the documentation.  Have you tried the official Netgear support
        channels, or would that now be costly?
