whitehat007
Sep 30, 2016Aspirant
Disappointed with the router as it doesn't have important feature to set bandwidth to scope of ips
WNDR3400v3 Case ID: 27440470 I am really disappointed with the router as it doesn't have important feature to set bandwidth to scope of ips. My previous routers which were 1/4th price of net...
- Sep 30, 2016
I wouldn't hold my breath. You can use QOS to prioritize traffic for various devices. Unfortunately, it cannot enforce per-device bandwidth caps. You will have to look elsewhere to find something suitable for your needs.
TheEther
Sep 30, 2016Guru
- Retired_MemberSep 30, 2016
Who makes this router? The 3400 is sold all over for $70 and you're saying some company makes a router with those features for way less.
- whitehat007Sep 30, 2016Aspirant
I called up netgear product service they say none of the netgear router has ip based bandwidth cap limit option.Which router to buy i am confused.
I dont want per device allocation i need for ip scopes.
- ElaineMOct 03, 2016NETGEAR Employee Retired
whitehat007 I apologize but there's no more future updates for the router. It's been EOL for a long time.
Just like what TheEther had mentioned the router cannot provide bandwidth limitation per device nor IP scopes.
