Blackrain2k's avatar
Jun 08, 2021
EX6150 5ghz drop
Hi everybody
i have used my EX6150 with 2.4ghz for years without any problem. Now that i bought a modem/router that supports 5ghz I tried to configure the extender to use such bandwith. The extender succesfully connect to the 5ghz wifi but then the connection drop down and only with a power off/on cycle I can get it back.
Does anybody experienced the same issue? Any suggestions?
Firmware Version: V1.0.0.34_1.0.69
Thank you for your help!
Andrea
  • just to let you know that I have probably found the solution:
    I have  changed the wifi channel from my router and now i am no experiencing any drops in the connection
    hope that this can be helpfull to others
    • Blackrain2k's avatar
      Blackrain2k
      Tutor
      Hi Plemans, thank you for your quick reply!
      I am using the router provided by my carrier:
      Technicolor MediaAccess DGA4131FWB
      and setting it up with the installation assistant
      Andrea
      • plemans's avatar
        I couldn't find much info on that router (never a good sign)
        A couple things you can try.
        1. update the firmware on that extender. Looks a couple behind
        2. setup the extender with a static ip address in your router
