Johnz414's avatar
Johnz414
How do I setup ipvanish on netgear N600 router?
Hi,
Just that. How do i setup ipvanish on a Netgear N600 router?
Thanks,
John
  • michaelkenward's avatar
    michaelkenward
    Netgear makes dozens of N600 routers. Which one do you have?
    Look for the model number:
    model number
    Then you can find the manual on Netgear's support site.
    Support | NETGEAR
    • Johnz414's avatar
      Johnz414
      It is a Netgear RT-N53 Dual-Band Wireless N600.
      I've seen options where you have to install the DD-WRT firmware to add the VPN but when I looked at the DD-WRT site it didn't seem to offer a firemware for this router?
      Also, I just found this YouTube video explaining how to set a a VPN without flashing the router. I would like to know if this would work for the router I am working on?
      https://www.youtube.com/watch?v=pb2Wyv-PDvc
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        That model sounds from a different manufacturer. You can verify the model number here
        The router doesn't support IPVanish unless you use a different firmware or hardware.
