Krishnakall1973's avatar
Nov 28, 2015
JNR1010v2 - Router does not connect to internet
Hello,
I have a 3 month old netgear wifi router, model number JNR1010v2. It was working fine until recently. It does not connect to the internet since the last two weeks. However, I am able to connect to the inetenet if i connect the ethernet cable directly to my laptop or PC. If i connect the same ethernet cable to the router, the led for the internet does not light up & i am unable to connect to internet,
I tried connecting my rotuer to my firend's connection with the same result. His router works fine on the same link.
Can you please suggest a suitable remedy?
Details:
Model Number: JNR1010v2
ISP: ACT internet (Provides an ethernet cable to home).
Thanks in advance
Krishna
  • Elaine
    Thank you for your note. I did try the setup & much more. It has been confirmed that it is a hardware fault on the internet port in the router. I will be exchanging the router for a new one.
    Best Regards
    Krishna
  • Additional Notes:
    The PC is able to connect to rotuer just fine. However, running the initial setup again after a factory reset gives the following error - 'Please check if ethernet cable is connected'.
    As stated earlier, the ethernet cable works just fine if it is connected to the PC directly,
    Any troubleshooting or fix suggestions would be greatly appreciated.
    Thanks in advance
    KRishna
      • Krishnakall1973's avatar
        Krishnakall1973
        Elaine
        Best Regards
        Krishna
