LyletheIceman's avatar
Dec 01, 2016
My PS4 will connect to my N750 router and the internet, but can't use PSN.
I am having an issue with my WNDR4300 N750 WiFi Dual Band Gigabit Router running on firmware version V1.0.0.32. It would seem that this router is cutting off connections with the Playstation Network....
  • LyletheIceman's avatar
    LyletheIceman
    Dec 06, 2016
    My PS4 is connected wirelessly, and no other device that we've used has had the issue so far. I changed the MTU down several times, and I'm afraid that didn't solve the problem. However, I think the problem might be elsewhere, as I was able to use an entirely different router and still had the same problem, so it appears that the router is not the issue.
