resemo's avatar
resemo
No ADSL Settings on my WNR614/N300 NetGear router
Hi All,
This is my first post here. I just bought a NetGear WNR614 wireless router, and I'm having issues setting it up.
The router is connected to via WAN to a ZTE router. I need to configure the ADSL settings, but its not available. I cannot input the multiplexing method or any ADSL configuration since the tab is not present.
Only the Internet, WAN, LAN and Guest Network are present.
Any help appreciated please.
Thanks.
  • If you mean how do you "set your modem in bridge mode", check the modem's manual.
    But with four other routers/access points you seem to have a pretty complicated network.
    You can find the documentation for your Netgear stuff here:
    WNR614 | Product | Support | NETGEAR
    The documentation clearly lays out the order in which you need to do things:
    • Unplug and turn off the cable or DSL broadband modem.
    • Unplug the router.
    • Plug in the cable or DSL broadband modem and turn it on.
    • Wait two minutes.
    • Plug in the router and wait two minutes.
  • Retired_Member's avatar
    Retired_Member
    You bought the wrong router if requiring ADSL settings.
    • resemo's avatar
      resemo
      What do you mean bought the wrong router? Its out of the box. How can there be no ADSL settings in a router.
        Retired_Member
        So your suggesting all routers have a ADSL modem?
  • michaelkenward's avatar
    michaelkenward
    Is that a ZTE router modem?
    You'll need one modem somewhere in the system to connect to ADSL.
    • resemo's avatar
      resemo
      Yes, the ZTE is an ADSL router/modem, which feeds 4 other routers/access points - with seperate SSIDs.
      The problem is that the NetGear doesn't want to detect the internet connection signal, and there are no ADSL settings.
      Not sure what the problem is tbh.
